Mep-803a top cover off with questions
chilbun28
Deep South
I removed the top cover for the motor compartment to change the fuel return lines and notice these white cables with corroded looking wires/fittings. Are these grounding and bonding connections? I'm assuming I should make up new cables for it and replace them while the cover is off. Anyone have any suggestions on them? Thanks
jamawieb
556
Ripley/TN
I would for sure clean all that up, Guyfang gave you the answer. Dirty connections could have caused the shorting. Make sure you take the glowplugs out and check them because I've had them burn up and break. When they break they can get sucked into the intake and cause all kinds of engine problems.
loosegravel
Just a retired mechanic who's having fun!
504
891
Enumclaw, Washington
Aside from the corrosion on top of that LPW4 engine, those glow plug cables look like they've had some high current in them. I'd be checking the R value of each of the glow plugs (with each one isolated from the rest) and also check the glow plug relay for possible sticking. I've read here in this forum that it does happen, although I've personally never experienced that scenario. Was this unit stored out in the open with the top cover removed? Was it stored near salt water?
loosegravel
504
891
I just got it not long ago, not sure of its history. It runs well. Can I buy new cables and just buy new ones and change them out? Don't know my way around diesel engines very much....
You’ll find lots of help on this forum. It’s best to test and replace parts as needed rather than just replacing them. It’s also a lot less expensive. Those cables may look “bad” but still have a lot of integrity left in them. One of the best ways (and most suggested on this forum) to get to know your machine is to read the technical manuals. (TM’s) These machines are very well designed and relatively easy to troubleshoot once you get to know them. Good luck and have some fun while getting to know your machine!
chilbun28
Deep South
Thanks, where can I find the technical manuals?
Ray70
5,860
West greenwich/RI
You can make up some new wires if you get the right size terminal ends and the appropriate crimping tool.
I can also look through my spares piles and see if I have a full set of wires available, if you'd like.
Step 1 though, make sure you can get the "Nuts" off the pre-heaters. Sometimes they get corroded and stuck because they are aluminum.
Forcing them can cause the center of the heater to spin and ruin the heating element.
