MAdams
- 125
- 43
- San Dimas, CA
I just bought this unit and it ran but made no voltage. I adjusted the mag pickup and moved the high/low voltage board to the low position. Now the engine will only stay running if the main switch is held in the start position. It runs great but once I let off switch the engine shuts off. The mag pickup has 750 ohms and I have adjusted AC voltage when using the dead crank switch to 2.7vac. I also bought a new mag pickup just in case but I have the same results.
The only other work I have done is move the board to the low voltage spot.
Any ideas?
Any ideas?
