Landshark_3
- 16
- 3
- Kentucky
I have a MEP-804A I have been working on. I got all the bugs worked out but maybe one. This does not make any sense to me so hopefully someone has some insight.
This generator purrs like a kitten, runs great. It starts easy and has low hours, but on two different occasions it would not start. It seemed to turn over just fine but would not event try to start. This happened just after I replaced the VR and Governor control. So I started looking into it. I just to make sure I put a battery charger on it to make sure the batteries were fully charged. I came back after the charge and it started right up. It has done this on 2 different occasions. It will crank what appears to be at the normal speed but not start, charge the battery and it starts right up.
I did find the battery meter not showing a charge and found the belt loose and tightened it. This seems to have been the source of the real issue. My question is why if the battery will turn the machine over at what seems like a normal speed, but the battery may be a little low why will it not start? Is there something monitoring battery voltage or engine speed that prevents the fuel shutoff from opening? Like I said the issue seems to be fixed I just wonder what the real issue is.
