- 2,007
- 3,209
- 113
- Pepperell, Massachusetts
MEP-804A, MEP-804B, MEP-805A, MEP-806A Replacement A1 AC Voltage Regulator
Replaces 6110-01-368-7123, 6110-01-379-7187, 19870, 19890-001, 6110-01-374-0836, 6110-01-384-7192, 122-3055, 19880-1, 6110-01-384-7063, 6110-01-384-7352, 19880-002, 19890-003,
Features include:
• Can be used regardless if factory Voltage Regulator was made by Libby or Technology Research Corporation (TRC)
• Replacement for your defective or missing Voltage Regulator... or to have a spare on hand!
• Does not use the existing T1 transformer, R1 or R16 resistor (no need to remove or replace them)
• Input and output fuse protection. Fuse's are easily replaced if ever needed.
• Works with or without the "Fuse Mod" (Fuse Mod is not needed with this regulator)
• Includes new pre-wired front panel R1 voltage adjustment potentiometer
• New mounting hardware, wire labels Zip ties & detailed instructions included for installation
Easy Installation:
• Remove and label 12 wires from existing Voltage Regulator
• Remove existing Voltage Regulator
• Install new Voltage Regulator & reconnect the 12 wires.
• Remove existing voltage adjustment potentiometer from front panel.
• Install new pre-wired voltage adjust potentiometer in front panel.
• Connect four clearly labeled wires to four points behind the control panel.
• Install supplied Zip Ties to secure wiring.
Limitations
• Does not support parallel generator operation
• 60 Hz operation only
I personally assemble each of the Voltage Regulators. Once built each Voltage Regulator is adjusted and load tested in a MEP to assure a defect free unit.
Ordering Information
Cost: $280 Includes USPS Priority Shipping in the US
PayPal & Checks accepted. Quantity discounts available
To order email me at: kurtklopp@gmail.com
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
Features include:
Easy Installation:
Limitations
2) Payment Method
