Mep-804a power output problems
drhurtado
Puerto Rico
I am new and without experience.
I just got a Libby MEP-804A from auction and followed all instructions to adequately use it. It turns on and everything looks fine for the first time. All the dials and clocks were apparently working fine. We tested the convenience outlet and had power.
Next day we turn on the unit and started but no voltage or any of the power readers were functioning. The AC interruptor light only turn green if I keep it pressed up. Still no power unless I keep the start position and the ac interruptor pressed at the same time.
Any ideas?
Guyfang
23,046
Burgkunstadt, Germany
You need to hold the S1 (start switch) up longer, when you start the set. Hold it up until the volts and hertz meter both read right, then let go. Has the Quad circuit modification been installed? If you don't know what it is, let us know.
Guyfang
23,046
Take a picture of the inside of the control panel, right side. Then we can see if the mod is done. You need to download the TM's and read the operators manual.
Try this. Start the set. Keep S1 in the start position. Flip up the S7. Release the S1. Do any idiot lights come on. Do your meters read now?
drhurtado
Puerto Rico
ill do tomorrow. I read both and looked over internet for troubleshoot. When it arrived I installed the 2 new batteries , followed all the operations and start it. Everything looked fine and all the diales were functional, tested the convenience outlet with a power tool and worked. had no change to prove the ac output as was going to be connected to a deep well pump. The next day I was able to start it normally but no power in the dials was recorded. Using this forum did some troubleshooting and identified that dials work when the S1 is hold in start position and current measured using a meter at ac output when both start is hols and the ac interruptor is hold in close position were it turns the light green. Also the interruptor does not hold in close position with light on unless I push it upward. This is my current situation.
Guyfang
23,046
In the first picture, the DC control fuse and cap are missing. If you don't, replace them, then the battery's will not charge. Look around inside the control panel. Most of the time they are someplace in there.
in the last two pictures, you can see the Quad fuse MWO is applied. You need to check the fuse. If it's bad, the generator will not produce power.
drhurtado
Puerto Rico
image.jpgIt was in the floor just put it back. The fuse was tested and functional. Still no power unless hola start position and ac interruptor hold up in close position
Guyfang
23,046
Start the set. Hold up the S1 in the start position. Flip up the S7, then let the S1 go. Do you still have power?
If you do this, and you still have power, then its possible that K15 is bad, or not getting a signal from someplace else. Remove K15 and K16, and swap them. Then try to start it again.
Guyfang
23,046
Did you test the Quad fuse? I was not talking about the DC battery charging fuse.
Guyfang
23,046
Have you done this? Has it changed anything? Do you get a different fault light?
