MEP 804b starting issue
mudslinger92
Raeford,NC
I have a 804b yanmar turbo generator. It has started spinning over and not starting recently. If cut it off and wait about 30-minutes to an hour and come back it will start right up and the next day it may or may not start unless you wait again. I have checked the crank sensor and it is at 2.8 volts ac. It is showing good oil pressure on the gauge. What else could I check? Could another sensor be failing and telling it not to start? Thanks for any help!
