wittkins
- 2
- 3
- Ventura, CA
I recently purchased a MEP 805B. I have downloaded the User Manuel (MEP805B-MEP815B-Operator-Manual) and reviewed but am at a loss. The CIM shows I am producing 220 volts but...
When I go to check the output voltage at the load output terminal board, there is zero voltage.
Notes: My GFCI reset springs back and does not lock in place like a residential one would.... how do you check these? should it be locking in?
I am in the process of building the switch to fix my dim CIM so I cannot see if Contactor position is set to closed on the CIM screen. How long do I need to hold it in the closed position before that is set?
Assuming my GFCI is bad, where can I purchase a new one?
Other suggestions?
Any help would be really appreciated.
Adam Wittkins
Other suggestions?
Adam Wittkins
