MEP-805B Oil Pressure Issue
MRAD338
Hill City, KS
Good morning,
I have an 805B that runs great but will not produce power. The CRT says no oil pressure which I'm sure is causing the problem, but using a manual gauge it shows 65 psi. Any thoughts on this would be greatly appreciated. TIA
Guyfang
23,904
Burgkunstadt, Germany
Are you getting a failure code? Normally, if the CIM shows a "no engine oil pressure" failure, the gen set will stop running. There will be a fault code displayed.
By: The CRT says no oil pressure, you mean that the gage shows no pressure, or that the CRT gives you a message that there is no oil pressure?
Are your batteries in good condition? If they are low or weak, the gen set can often have very strange faults.
Did you hold the start switch up long enough? You should hold it up until both AC Volts and Hertz read correctly.
MRAD338
Hill City, KS
HI, There isn't a traditional pressure gage so i had to buy a manual gage to verify operating pressure, and it does have pressure physically. The monitor shows the low oil pressure as a fault prior to and after engine start. It has brand new batteries. I have not held the start lever over until producing power, but i did toggle to start trying to excite the field. I will take some pictures and a video tonight and post here tomorrow. TIA
justinn
211
33
THE GREAT STATE OF TEXAS
I would check the wiring to/from the oil pressure sending unit. Although the sending units ~can go bad, wiring has been the culprit in the ones I've messed with(not an 805B in particular though).
Justin
nextalcupfan
506
NW Missouri
Let me know how it goes, I am in Basehor, KS about 5 hour drive east from you.
Peter
Wow I had no idea you were so close to me, I'm less than an hour North of you.
I would love to offer to help by going to but my knowledge would be a pittance compared to yours as I've only ever worked on my 803A.
