- 6,851
- 670
- 113
- Stratford/Connecticut
I have a mep 816. Runs fine makes power. The pickup tube was loose when I got it. It’s a very long tube for the tank size. It seems too long to fit. Is there some magic trick I am missing?
And the start switch has aux prime and prime. Aux prime runs the only electric pump that I see in the gen. I had to use the hand lever on the mechanical fuel pump to prime it. Is there supposed to be an electric pump?
The fuel sender or low fuel switch is cut. I am figuring one wire goes to the center post and one to the sender base.
![77D169C7-15CE-45F6-8652-DEF9D51C8C69.jpg 77D169C7-15CE-45F6-8652-DEF9D51C8C69.jpg](https://www.steelsoldiers.com/data/attachments/528/528922-47d1f75625543c7e95e0bab3f099a2ad.jpg)
![B6722BF6-39A3-4C6B-BD54-6CABDF626BF0.jpg B6722BF6-39A3-4C6B-BD54-6CABDF626BF0.jpg](https://www.steelsoldiers.com/data/attachments/528/528923-725c70cb2f5718a39f8a3e018f4c20ce.jpg)
![72F12239-491C-42FF-8453-8C4B34166ADF.jpg 72F12239-491C-42FF-8453-8C4B34166ADF.jpg](https://www.steelsoldiers.com/data/attachments/528/528924-5f5b884b4dfb2b841019e6d81f95e659.jpg)
