To start, I just got a 803a in that had the gen head and engine recently replaced. The top panels were removed when I picked it up. My problem is the fuel cutoff solenoid is not getting 24v to retract. It is getting 24v on the hold signal so I can turn s1 to prime/run and pull the solenoid back manually and it will hold and I can start it. Everything else works perfect. The schematic show the pull signal coming from K16 terminal 7. Im not getting 24v there. Then it looks like terminal 7 is feed by terminal 9 which gets power from k12-2. Im getting voltage on k12-2 and k16-9 but it does not go over to terminal 7. I switched relays and same results. Wanted to see if anyone could see something Im missing or had a similar issue.
