- 6,850
- 670
- 113
- Stratford/Connecticut
I have a mep-814a generator. I am having some trouble with the fuel system. It has a primer pump just below the IP. There are 2 bleeder bolts on the IP. I can crack them open and prime the pump it will draw fuel and then start but die a few moments later and have lost prime or sucked air. I know it has an electrical fuel pump also. Is the electric pump just for priming or does it always run to feed the engine? If this is the case why have a mechanical pump also? The fuel path comes up from the tank right into the primer pump then thru filters and into the IP. I don't have any experience with these newer gens and I found some TMs online I couldn't find anything that talked about the primer pump or maintenance level fuel system troubleshooting. Everything was operator level. Any help would be appreciated.
Will
Will
