Mep 831 a inverter stand alone set up
Millerinfantryvet
Colorado
Hello, i have a bachelors in Electrical engineering. I love to create new gadgets and what not.
i have a power inverter from a mep 831a. the actual power inverter box. i cannot find a pinout diagram that shows where the input voltage comes in to. i have the army tm but it does not show alot. does anyone know which input wires in the j-17 connector is the 120v or so input? like if i wanted to hard wire in 120v and use the inverter as a stand alone 240v inverter. its possible i just dont know which one is the 120 in i know the 240 and 120v comes from the dist block on top, that says l1 l2 N l1 and N IS 120 l1 l2 N IS the 3 wire 240v. i have it torn down upgraded inside components. Im stuck at knowing where the input wires are. thank you.
