MEP-831 NSN 114250-66440 Bolt
zapp
49
Ohio
Hello - I noticed the bolt and jam nut is missing on the bracket assembly. I looked up the part number and did a quick google search to try and see the length/pitch of the bolt to source locally but not seeing description. Is there a specific site or way to easily look up the actual descriptions for NSN's versus just seeing what google gives back? Also, does anybody know the pitch/length on the bolt 38 & 39?
kloppk
4,178
Pepperell, Massachusetts
FYI - 114250-66440 is Yanmar's part number for the bolt and is not the NSN number for it.
The actual NSN number is: 5306-01-431-7459
Info about MEP part numbers and NSN numbers can be looked up at Parttarget.com
That bolt is a Yanmar unique M6 bolt with a hole in the head for the locking wire.
It thread length from the bottom of the head is 4 cm
zapp
49
Ohio
Perfect, thanks! Having trouble finding anything in stock online but will give a local sourced M6x1.0x4 a try.
2Pbfeet
1,478
Mt. Hamilton, CA
FWIW: that Yanmar bolt is available from a number of sources, both Yanmar, and open market. Try using the Yanmar part number, or
"M6x40 safety wire bolt"
In a pinch, you could use and m6x40 with an extra jam nut.
For about $15, you can buy a jig for drilling the bolt head and a jig for drilling the threads. (Amazon)
All the best,
2Pbfeet
