- 3,744
- 5,648
- 113
- MA
I've seen so many sets come up missing this piece. Whats the deal... poor reliability on the part (so constant scavenging)? Any availability on the secondary market?
Hopefully I can help out on that thread at some point when I have time and space to work on it.Wondering the same. one of my on-hold projects is repair of a bad inverter that does produce voltage, just way too high.
I have a thread with some of my findings back when I only had 1 831, but since I have 3 now and at least 1 working inverter I have this project on hold.
thread: https://www.steelsoldiers.com/showt...ody-have-luck-with-repairing-these&highlight=
For this thread I am wondering what the failure mode is for the majority of the ones out there.
I thought it through and I am going to just buy a gen head from northern tool that will fit into the same enclosure I measured it and it will work, all you do and remove the governor assembly and inverter and just run it with the built engine governor at 3600 rpm in reality it only changes a few hundred rpm the way its setup now, will keep yall posted on progress but it is just pretty straight forward! You would remove the PMG (alternator on side of engine and directly bolt gen head onto engine its about 300 bucks and bolts directly onto the yanmar engine and is small enough to fit into the MEP831 enclousure, it is a four wire generator so it can be wired for 120 only or option of 120/240 but this may cause problems with the other controls. Everything stays the same and you will not have to deal with inverter or governor assembly anymore. Only problem I see is shutting it down but I found some injector pumps off E*** for about 80 bucks that have a electric solenoid built in which could be tied into the low oil/overheat circuit.
Marty
I'll send you a PMLooks great, @kloppk. I think I have a 1659201 generator head somewhere (maybe), I'll have to dig around for it. Not sure if this old 831AE is worth the cost or trouble if I have to go hunting a used generator head down though. If I can find it I'd be interested in your kit for sure, what would that run me?
I would like some more information about the conversion kits you sell please.Unfortunately Northern Tool hasn't carried that gen head for a few years.
Yes, the Northern Tool gen head does fit on the Yanmar in the 831A. I have one on an 831 in my garage. Pic below.
The equivalent gen head can be purchased from Mecc Alt. I've bought a few of them from them the last couple of years to do conversions.
FYI - I produce conversions kits to do the swap which includes a custom governor controller to maintain 60 Hz, current sensors for overload protection and a transformer assembly to restore battery charger operation and all needed hardware.
Here’s my post on doing my conversion.I would like some more information about the conversion kits you sell please.
The conversion involves removing the inverter, PMA and SLC100 Governor Controller module.I would like some more information about the conversion kits you sell please.
