Hello.
I did end up getting an 831A and the inverter even works. Rats had lived in it and chewed through the fuel pump wire and were making nest material from the insulation but really not bad shape once cleaned up. My question is about the voltage meter. This one peggs all the way to the right when it's running but comes back to zero when not running. So it works ish. I have verified 240 volts with my fluke. I bought a different guage off ebay and it was very faded and discolored but that wasn't the problem. Once I went to fine tune the voltage reading the plastic adjustment on the front of the meter disintegrated and my screwdriver went right into the guage. Lol. Oops. Okay so back to my guage. It has moisture in it. Every day the glass has moisture on it. I'm wondering if that has something to do with it maxing out when voltage is applied. It says it's sealed on the back and the fact that the moisture isn't drying even though we are having 100+ degree days with low humidity here in south east NM. I believe it. Finally my question is has anyone looked inside one of these and might know where the safe place to drill a small hole in the case to let the moisture dry out then I could seal it with a dab of silicone once it's dry. I just don't want to drill into it and mess up the works inside it. Does anyone know a reason I shouldn't do that? It works enough now to indicate voltage just not set it.
