- 2,034
- 3,280
- 113
- Pepperell, Massachusetts
MEP-831A Remote Start Controller System
Wi-Fi Remote Control & 2-Wire Start/Stop
Include improved Governor Controller
Adds display of Oil Pressure and Crankcase Temperature
Features include:
· Remote genset Start/Stop via WIFI via cell phone, laptop, tablet
· Direct WiFi communication. No router needed. Works during power failures. (Version available with home WiFi network integration)
· 300 foot plus WiFi range. Password protected
· Browser display of all engine and generator operating parameters on remote WIFI device. Parameters nearing extremes are highlighted in red text.
· Ambient Temperature
· Battery Voltage
· AC Voltage
· %Load
· Fuel Level
· Crankcase Temperature
· Oil Pressure
· Remotely Enable and Disable the Auxiliary Fuel Pump
· Remote control of the Contactor with the Contactor state displayed
· User calibration of all parameters
· Data Logging of all parameters as well as engine hours and Start/Stop count. Min, Average & Max values logged every 10 seconds.
· Two wire remote Start/Stop for use with ATS, Solar Charge Controller or a simple toggle switch
· Transfer between WIFI and Manual control while running
· Automatic Pre-Heat below 40 degrees F
Additional features
· User programmable durations and delays for all phases of start up and shutdown. Separate delay settings for WiFi Start/Stop and 2 Wire Start/Stop
· Pre-Heat duration
· Fuel System prime duration
· Cranking duration
· Warm up
· Stop command to contactor open delay
· Cool down delay
· Adds reporting of oil pressure
· Adds reporting of crankcase temperature
· Also replaces the problematic factory A5 Governor controller will all the features of my replacement Governor Controller board
· Wire Harness made with high temperature MIL Spec Wire
· Antenna and connector are IP65 rated for water resistance.
· Retains full manual control of the genset
· Controller is conformally coated to seal out moisture.
· Includes Controller, wire harness, all hardware for installation & manual
· 1 year warranty
I personally assemble each of the Controllers and wire harnesses. Once built each Controller is tested in a MEP-831A and calibrated to assure a defect free unit.
Ordering Information
Cost: $600 Includes USPS Priority Shipping in the US
PayPal & Checks accepted
To order email me at: kurtklopp@gmail.com
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
Controller mounted on control cube
Supplied Pre-Assembled and tested wire harness
Supplied mounting hardware
Supplied Oil Pressure and Temperature Sensor
Feel free to PM or email me with any questions!
