MEP Jerry can adapters vs. 55 gallon drum adapters
derf
13
LA
I think I found the answer:
55 gallon drum bungs are the same dimension as Jerry Can openings, use the drum bung adapter without the extension for Jerry Can fueling
n1oty
Taunton, MA
Geez, I simply take my length of fuel hose, attach one end to the auxiliary intake on the generator and stick the other end into the can or drum. KISS principal.
John
SCSG-G4
PSVB 3003
5,398
3,486
Lexington, South Carolina
The tube that goes on the bung adapter is the correct length for a five gallon can, the addition of the second tube, which screws into the first one, makes the correct length for a 55 gallon drum.
