- 45
- 4
- 8
- Fort Worth, Texas
I am about to put a LOT of hours on a MEP-806B that has ~ 460 hours on it.
The oil & air filters were changed @ 405 Hours, according to a hand written note on the air filter canister.
I've scanned though the TM, & specifically checked the "TABLE 4-3. UNIT PREVENTIVE MAINTENANCE CHECKS AND SERVICES (PMCS)", but it doesn't mention anything about adjusting the valves.
I found a John Deere 6068 service manual dated 1993 & maybe updated 1997, so it might not be relevant to my JD 6068TF151A, C engine dated 5/2011, but it states that the valves should be adjusted at 400 hours.
So, my question is this: Does anybody know if, IN GENERAL, preventative maintenance on MEP units included adjusting the valves?
I checked the valve cover & didn't see any tool marks around the access plugs on the valve cover, indicating they had been removed:
![IMG_0047.jpg IMG_0047.jpg](https://www.steelsoldiers.com/data/attachments/478/478126-2642ee722f92bfe20b4e73affb49b28a.jpg)
![IMG_0048.jpg IMG_0048.jpg](https://www.steelsoldiers.com/data/attachments/478/478127-1312e809c469028b1f153bc207eeede4.jpg)
Aha!!
I just found this in the ARMY TM 9-2815-260-24:
4 M 1500 (ie, 1,500 Hours) Engine Valves Adjust engine valves at Direct Support maintenance level. See paragraph 4.7.2.
So, it looks like these valves need to be adjusted @ 1,500 hours & the entire engine should be pulled to perform the work:
I answered my own question, but I wanted to share what I found in case anybody else had the same question.
Cheers!!
Franko
Aha!!
4.7.2. INTAKE AND EXHAUST VALVE CHECKS AND ADJUSTMENTS.NOTEThe following procedures require complete access to the engine. Ifnecessary, remove engine from generator set, refer to TM 9-6115-672-14.Mount engine on repair stand (NSN 4910-01-016-1835 or equal) as outlinedin paragraph 4.10.a. Adjust.NOTESetting engine with No. 1 Piston at TDC Compression stroke is required inmany different maintenance steps and is not a stand alone maintenanceprocedure.(1) Set Engine with No. 1 Piston at TDC (Top Dead Center) Compression Stroke.
Cheers!!
Franko
