Just FYI, four stroke, not two stroke.Yea I thought that might be the case. 2 stroke diesel, air cooled. No water jacket to attenuate noise. It;s currently under a roof and I had planned on adding sides. We live in the country so noise bothering the neighbors isn't a problem. More of q curiosity question. I'll just add some pipe and turn the end down to keep the rain out. Maybe a screen to keep the wasps out.
Just keep in mind that if you end up using iron pipe and extend it every far horizontally you will need to support the pipe. Vibrations will be transmitted to any exhaust pipe extension which can become accentuated and lead to cracking of muffler or exhaust manifold if run too long a distance unsupported. Exhaust flex pipe is generally lighter and works best....I'll just add some pipe and turn the end down to keep the rain out. Maybe a screen to keep the wasps out.
