Armada
- 4
- 0
- Buick City, MI
I thought I remembered this being discussed before but ran a search and didn't find anything so I'll ask.
I've got an mep002 genset that will not send charge to the batteries. I checked the fuse to the battery charging alternator and it is ok. This unit has the ASK on it and will need to come off before I diagnose any further. The genset had been sitting a long time before I got it so I'm thinking (hoping), there may be some corrosion on some contacts that is preventing it from operating, like there was on the fuel shut-off solenoid. The genset had been overhauled with less than an hour on it so it's not likely the alternator is worn out, but anything is possible. The TM lists a couple checks to make, but before I tear the thing apart to get to the alternator, have any of you had a similar problem and what did you do to correct it? Hoping it's something common and easy like cleaning a contact. Thanks.
