MEP002 runs but not right
oshpunit987
Bethesda, Ohio
I got a new rebuilt engine last summer and mounted it. The paper work that came with it showed it was dynoed and ran good. Today I started it and it will not go up to the correct speed. The only thing I can imagine being wrong is the throttle cable needs adjusted nothing else was changed. I can bring the rpm up by moving the pump linkage but am afraid to do much with it because it runs so slow and may burn up the voltage regulator. Can the generator be unplugged so the engine can be adjusted to the correct rpm to keep from damaging the VR? Does any one have any idea what my problem is? I have the 3 TM's and can't find any thing about it.
Allen :D
oshpunit987
Bethesda, Ohio
With the throttle pulled all the way out it knocks a lot. I don't know what RPM it is making but I know it is too slow. When I first tried to start it it wouldn't make any oil pressure. I assume it had to fill the oil filter and fill the oil passages to make any pressure. When it did start it went up to 50 PSI.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Can't you just unplug the wire harness going to the control box? Special Ed is out your way, maybe he will see the thread and give you some pointers. I bet he could be bribed to maybe stop out and check it over.
oshpunit987
Bethesda, Ohio
Thanks gimpy
I was wondering if I could do some thing like that. I assume the big plug on the back of the control panel is the one I unplug? Would I need to do any thing else or just start it and start tuning?
Allen
gimpyrobb
27,791
791
Cincy Ohio
That question was put out there for someone else to say "yes" to. I am not sure it works like that, I would like someone to confirm.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
Allen,
Before you do much at all with it, you need a good tach so you can tell the actual RPM of the engine. More than likely the Governor needs adjusted and you'll probably be fine. The adjustment procedure is in the -34 TM section 7-3. But unless you are confident you have a good frequency meter or have access to a good external frequency meter you will need a tach to adjust it. If you don't have one or need help let me know and I can probably make it over to help out sometime soon.
oshpunit987
Bethesda, Ohio
Allen,
Tom
The only thing I have to check stuff is a multi meter from harbor freight and it doesn't have a frequency meter in it. I made a copy of the governor adjustment procedure a few days ago but I don't really understand all of it. If you don't mind I would really appreciate it if you could give me a hand getting this thing running.
Allen:)
Speddmon
32
Cambridge, Ohio
PM inbound. We'll try to come up with a day I'm of work and we can get together.
