jlboyce
- 0
- 0
- canon city, co
Hello all. I am brand new to the Forum, and hail from the eastern slope of the rockies, near the Royal Gorge.
I have an MEP003-A that I just reconditioned the injectors in, and the machine was received with 3 broken glow plugs. I don't want to pull heads, so now need to get manifold heaters working. I am aware that this machine uses 2 12v heaters in series, and have researched all the posts I can find on here to try to determine the grounding scheme for the heaters. I find that the aluminum plate which the heaters are screwed into is totally electrically isolated from the intake manifold. In a post I found here, it is mentioned that a wire runs from one of the mounting plate bolts up to one of the manifold mounting bolts. I find no such wire nor any evidence of such wire on my machine. Will I fry the heaters if I remove the insulating sleeve and washer from one of the mounting plate bolts, to provide ground for the heaters? Anyone on here with experience with this circuit please advise me.
Thank you in advance for any help.
