elkhtr
- 12
- 18
- Stanwood, Wa.
I have been working my way through an issue with my generator.
Went to start it up prior to some yearly pm's.
Unit fired right up but died after about a minute.
Found cb1 tripped, reset and tried again, same result.
Started digging into it and ended up at the injector pump solenoid.
If I pull the ground wire, s2 to run, s9 on, no trip of cb1
Reattach ground, cb1 trips within 10 seconds.
Has anyone else seen an issue like this.
Is the solenoid a repairable item, or just replace?
Is it common for them to short internally?
The tech manual didn't really touch on the solenoid, more the pump itself.
No computer currently, so the manuals and wiring diagrams have been a challenge on a small screen.
