MEP004a, Exciter, T2 failure
joemarine
Houston, Texas
T2 failure. H1, H2 open primary. Center tapped secondaries, X1, X2, X3 are conductive. 72-2609=5950-00-600-0840.
Any ideas?
Is rewinding the primary winding practical? What Gauge wire...How many turns?
The plastic is OK. The tabs are OK. But the carbon smell is present.
Salvage availability?
Is MEP004a Exciter the same from MEP004 thru MEP007 for an Exciter assembly swap?
Thanks,
Joe
Guyfang
23,044
Burgkunstadt, Germany
The transformer is the same for the 004A and 005A, ONLY.
Rewiring is always an option.
Salvage availability? You have to look.
Below is all the tech data I have.
CENTER TO CENTER DISTANCE BETWEEN MOUNTING FACILITIES PARALLEL TO LENGTH4 8/25 INCHES MINIMUM SINGLE MOUNTING FACILITY SINGLE CENTER GROUP AND 4 11/25 INCHES MAXIMUM SINGLE MOUNTING FACILITY SINGLE CENTER GROUP
CENTER TO CENTER DISTANCE BETWEEN MOUNTING FACILITIES PARALLEL TO WIDTH3 69/100 INCHES MINIMUM SINGLE MOUNTING FACILITY SINGLE CENTER GROUP AND 3 81/100 INCHES MAXIMUM SINGLE MOUNTING FACILITY SINGLE CENTER GROUP
MOUNTING SLOT WIDTH0 39/125 INCHES NOMINAL SINGLE GROUP
FREQUENCY RATING50 HERTZ NOMINAL SINGLE COMPONENT OR 60 HERTZ NOMINAL SINGLE COMPONENT
INPUT-OUTPUT PHASE RELATIONSHIPSINGLE PHASE TO SINGLE PHASE SINGLE COMPONENT
WINDING SHIELDING METHODINTERNAL SHIELD BROUGHT OUT TO TERMINAL SINGLE COMPONENT
BODY LENGTH5 19/100 INCHES MINIMUM AND 5 31/100 INCHES MAXIMUM
BODY WIDTH5 INCHES MAXIMUM
BODY HEIGHT4 86/125 INCHES MINIMUM AND 4 203/250 INCHES MAXIMUM
END ITEM IDENTIFICATIONWSD: GENERATOR SET, 30 KW, 60 HZ, SKID-MOUNTED (3ID) (MEP-005A); GENERATOR, 15 KW, DIESEL, MILITARY STANDARD FAMILY; MAINT FACILITY, NIGHT SIGHT (NSMF), TAM E10227; AIRCRAFTS, STRATOFORTRESS B-52 AND B-1B
INCLOSURE TYPEFULLY INCLOSED
MOUNTING FACILITY QUANTITY4 SINGLE GROUP
MOUNTING METHODFLANGE SINGLE GROUP AND SLOT SINGLE GROUP
WINDING FUNCTION AND QUANTITY1 PRIMARY SINGLE COMPONENT AND 1 SECONDARY SINGLE COMPONENT
CRITICALITY CODE JUSTIFICATIONFEAT
WINDING OPERATING VOLTAGE124 AC VOLTS NOMINAL SINGLE COMPONENT SINGLE SECONDARY
WINDING OPERATING VOLTAGE208 AC VOLTS NOMINAL SINGLE COMPONENT SINGLE PRIMARY
SPECIAL FEATURESWEAPON SYSTEM ESSENTIAL
TERMINAL TYPE AND QUANTITY5 TAB, SOLDER LUG AND 1 WIRE LEAD W/LUG
joemarine
Houston, Texas
Couldn’t agree more. 450 is steep. Xfmr or exciter chassis Salvage /carcass would seem tenable. Any salvage opportunities between Houston and Dallas? That transformer is a boat anchor. Thanks!
flydude92
Waterville, Ohio
I found a company that would build one for $400 a few years ago. I was able to find a couple so I never needed it.
I may be able to find the info if needed.
flydude92
Waterville, Ohio
Here is the Information I have:
This email was a reply to a phone conversation I had with Kathy on 11/12/2013. I don't know if she is there anymore or if they
will still supply the transformer but at the time a few people were looking for replacements. It might be worth a try if all else fails.
Brian,
Here is the pricing you requested
P/n: 72-2609 Transformer
Qty: 1 Price: $425.00
Delivery: 1 week
Terms: Credit Card
FOB: Bethany, CT
Thanks,
Kathy
KATHY KOVACS AFCON PRODUCTS
35 SARGENT DRIVE
BETHANY, CT. 06524
203-393-9301 tel
203-393-9288 fax
