MEP004a Generator, Parts ID, Xfmr
joemarine
Houston, Texas
Transformer, Low Voltage, T3, on 50/60 Hz Static Exciter chassis.
I need the stock number to search for it. The part number or spec is not stated in the manual that I have. It simply says "transformer."
Looking into Jack 9 on the Exciter box front panel the primary is shunted by a 510 ohm wire wound resistor, R2. The primary is labeled H1, H2.
The secondary labeled X1, X2, leaves the exciter chassis by plug/jack 11 and enters the Voltage Regulator Board. The secondary drives 4 didoes in a bridge CR12,13,14,and 15.
It is part of the sensing circuit.
If I had to guess, the primary would see 120 vac, while the secondary would develop 24 vac to 48 vac?
Since it has opened there is no way to determine/measure the secondary voltage. If I knew what the proper secondary voltage was, I could secure a transformer from an air conditioning supplier, or parts store and mount it on the exciter chassis. (It looks like a 24V air conditioner transformer). If someone has an operating MEP004a, and is a cowboy, the secondary voltage can be determined by first checking the primary voltage that appears across R2. Then view the secondary voltage found at X1 to X2 terminals. That will give us the turns ratio to buy a proper transformer. I'm hoping that will make it work. Thanks, Joe.
Guyfang
23,044
Burgkunstadt, Germany
OK, what TM were you using to look up the part? I looked it up, and there is a NSN, so lets get on the same sheet of music. What TM, and figure number, Item number are you looking at?
joemarine
Houston, Texas
MEP-004a, T3, Exciter
The PIN:072239-001, manual, back page. paper
Army TM 9-6115-464-34, 18 Jan 1994, same manual, front page. paper
a pictorial diagram:
page 3-271....Fig 3-130 Static Exciter...item #45. It rests just behind the big wire wound resistors.
then on page 3-273, Fig 3-130 sheet 3 of 3, called "transformer"
a schematic diagram:
page 3-274...Fig. 3-131 50/60 Hz Static Exciter.... DWG No. 72-2629, the bottom "STATIC EXCITER" schematic diagram. Located in the lower left hand corner at the very bottom
is T3.
Thanks for your help, Joe
kloppk
3,252
Pepperell, Massachusetts
Joe,
I believe you need to look at TM 9-6115-464-24P to get the PN's.
The TM 9-6115-464-24P I have is dated 9-July-1992
The exploded diagram with ref #'s is on page 137.
Parts numbers are listed on page 141 and on.
Guyfang
23,044
Joe,
Exactly. The -34 is a pure maintenance manual.
Figure #34, Item # 41
NSN: 5950-00-600-0843
Description: TRANSFORMER
Part # 72-2618
Alt Part # 369B209G01
Cost: ABT 25.00
RELIABILITY INDICATORNOT ESTABLISHED
MOUNTING HOLE DIAMETER0 187/1000 INCHES NOMINAL SINGLE GROUP
FREQUENCY RATING50 HERTZ MINIMUM SINGLE COMPONENT AND 400 HERTZ MAXIMUM SINGLE COMPONENT
INPUT-OUTPUT PHASE RELATIONSHIPSINGLE PHASE TO SINGLE PHASE SINGLE COMPONENT
BODY LENGTH2 33/100 INCHES NOMINAL
BODY WIDTH1 33/50 INCHES MAXIMUM
BODY HEIGHT1 47/50 INCHES NOMINAL
DISTANCE BETWEEN MOUNTING FACILITY CENTERS2 203/250 INCHES NOMINAL SINGLE MOUNTING FACILITY SINGLE CENTER GROUP
INCLOSURE TYPEFULLY INCLOSED
MOUNTING FACILITY QUANTITY2 SINGLE GROUP
MOUNTING METHODFLANGE SINGLE GROUP AND UNTHREADED HOLE SINGLE GROUP
WINDING FUNCTION AND QUANTITY1 PRIMARY SINGLE COMPONENT AND 1 SECONDARY SINGLE COMPONENT
WINDING OPERATING VOLTAGE102 AC VOLTS NOMINAL SINGLE COMPONENT SINGLE SECONDARY
WINDING OPERATING VOLTAGE120 AC VOLTS NOMINAL SINGLE COMPONENT SINGLE PRIMARY
TERMINAL TYPE AND QUANTITY4 TAB, SOLDER LUG
Do you have all the TM's downloaded?
joemarine
Houston, Texas
Transformer, T3 Exciter board
Part # 72-2618
Cost: ABT 25.00
Yes, TM's downloaded, thanks.
You are right the -34 manual is maintenance.
24P manual lists parts. excellent. printed page 143 on paper
stock number 5950-00-600-0843
When I look at the xfmr in the bright sun that has just returned to Houston, I can make out 72-2618 through the rust....just barely.
That says we are on the right track.
If my memory serves me correct this transformer may take American 120Vac in the US to 100Vac found in Japan.
sources I gathered so far:
part number 72-2618, Correct Craft Inc, Afcon Products,
part number 369B209G01, Cegelec Automation Inc., Electric Machinery
part number 43674, Freed Transformer Co.
part number 40-12488, Magnetic Components, Inc.
part number 42297 Coast/ Advanced Chip magnetics, Inc
part number TP-2003, Hytronics Corp
these are suggestions...cross reference, and leads.... but not tested and confirmed on my end.
Do you have any suggestions for sources for the transformer?
Deeply appreciated....Joe
Guyfang
23,044
About 12 different firms sold this transformer to the gov.
I live in Germany, so sources might not help you from here. Just put the NSN and part numbers in your browser. Something will come up.
another helpful hint. The 004A and 005A are about 80-90% the same. Don't limit your self to just 004A, when looking.
