wanderingwillys
- 22
- 18
- Hobart, WA
Slightly different issue with my 005 - I can start and run just fine - holding the start switch will flash as designed and then I have Hz and V on the panel (and can adjust both with RPM and the Field Knob respectively) but I get nothing to the input of the main breaker (no power on either side or anywhere on the reconnection board) - the breaker seems to open and close normally and no alarm panel lights are lit.
I gather the generator is making power and the instruments pick it up somewhere very close to the winding but I am interrupted prior to the board...
Thoughts?
Thoughts?
