Mep005a star and runs for a few minutes
Juan3456
Nevada
Have a mep005a starts runs for a few minutes then dies has 1059 hours on it changed filters on it need help figuring it out thank you
Guyfang
24,998
Burgkunstadt, Germany
Have you ever seen this generator run right? Or is it new to you?
Have you downloaded the TM's from the forum?
How long is a few minutes?
Juan3456
Nevada
I had one line on pump that was loose fixed it and now I have the pr
Yes I had running for 5 -10 minutes before I have looked at some of the tms . I changed all filters checked day day tank, glass check ball valve and same issue
Juan3456
Nevada
I've downloaded a few tms on this mep005a 30 kw gen it has the whites inline 6 engine stadadyne roosa master ip
Guyfang
24,998
But you have never seen it run for say and hour? Or longer. This is important, to decide where to start looking for the problem. Your batterys are in tip, top condition?
Juan3456
Nevada
Has 2 new batteries no I haven't seen it run that long
Picked it up a few years ago
Guyfang
24,998
Can you make a film of what happens when you start it? And of the fault indicator when it stops? When it runs, how long will it run before it stops. How long is "a few minutes". Sudden stop? Long, slow stop? How much fuel do you have in the tank? Is the Day tank full? I need more info.
