MEP005A throttle question ??
R Racing
St. Leonard, MD
Ok I'm doing a engine swap and the engine coming out of the 400hz unit has a throttle governer with wiring and linkage. The 60hz unit doesn't have it or any support wiring or any signs of ever having it. So I get on GL and look at pictures of the same 60hz generators (4 to be exact) and they also dont have any governer or linkage or wiring either. So how does the 60hz govern its load ?? Or is there something I'm missing ??
PeterD
Jaffrey, NH
I think what R Racing is looking at is that the 400 Hz model is a precision setup (with a hydraulic governor) and the 60 Hz are utility units with the straight mechanical governor.
R Racing
St. Leonard, MD
So I guess the next question is can I use or should I use the electric governer setup from the 400hz ? Or should I swap injector pumps ? Or does the the 400hz pump also have some what of a internal governer ?
PeterD
Jaffrey, NH
I think the pumps are the same... I'd not try to swap in the bits and pieces for a precision set, there are a number of things that must be changed out. I've a injection pump from a precision model (or at least I was told it was a precision model) and it looks identical to my utility model injection pump.
I think all you do is to safety wire the governor lever to the end position, which your original injection pump should serve as an an example.
And, if I'm wrong, someone please jump in and say so! :p
R Racing
St. Leonard, MD
Thanks Peter!
Looking at my original 1 the arm is just a swinging in the breeze ? The pumps do look identical though. Anyone else have any thoughts on this ??
PeterD
Jaffrey, NH
Actually so was mine, but Ken who helped me get it running suggested we wire it, IIRC. In my case (and likely yours too) it doesn't move easily at all, so was not prone to jumping around. I think safety wiring is just a good idea--lot of vibration in these machines.
Isaac-1
50
SW, Louisiana
You will likely have to adjust the mechanical governor stop screw, in general when an electronic governor is added to a generator with a mechanical governor injection pump, the mechanical governor is set for a slower speed than the minimum droop of the electronic governor (say something like 54 hz in the case of a generator) so it does not confuse the electronic governor. If it were me I would transplant electronic governor, but that is just me, should be a speed sensor, control box and actuator.
Ike
kurtkds
-1
Puyallup, WA
Looking at the TM's there is a precision 60hz machine MEP-103a.
I'm in the process of hunting parts to convert my 400hz machine to a 60hz machine.
R Racing
St. Leonard, MD
Ike
Thanks Ike,
I have all the goodies to transplant , Only 1 box which isa large gold 1 that mounts to the side of the generator thats marked 400hz everything eles so far looks the same as the 60hz.
