icb818
- 0
- 0
- Millersport, Ohio
I have a MEP006A 60kw generator. Starts up fine, can't get voltage or Hertz up to where it will power things correctly. I think it might be an exciter problem... I put a volt meter on the on-board outlet and only get 39 volts... no matter the throttle setting, I can't get voltage required to run our facility. I was told to get a male to male end plug and plug into each outlet on generator in hopes of -energizing- the exciter?? I dunno.. it didn't work... another fella -former- military, told me when starting the generator, Hold the start toggle switch up/on until I get voltage reading... that didn't work... all others I've talked to in the 'generator industry' won't touch a refurbished military generator with a 10ft pole... they just keep saying.. "You Can't" as in Fix it?? Hmm... Really?? I kinda find that hard to believe...
So, anybody, former military dudes out there in Ohio, can ya give an old ice cream factory a hand??
please and thank you
David/Weldons.com![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
David/Weldons.com
