mrichard76
- 3
- 3
- Louisiana
I recently purchased a MEP007B that was load tested, producing correct voltage etc. Only issue then was the hertz meter was not functioning. Got it back home and now voltage meter also quit working and was only getting 120 volts across legs when measured at the lugs. Tried adjusting throttle to get 60 hertz (measured on multi meter) and was reading 137 volts across lugs, neutral to lugs or ground to lugs 8 volts. No electricity at 120v convenience outlets. Power coming into voltage meter at connections is 137v. Any ideas what's going on here?
