Jeepsinker
- 401
- 83
- Dry Creek, Louisiana
Finally got my 016c to put out power the other day and was load testing it when I found that it will not feed fuel from the belly tank up to the small tank on the side of the motor. Seems that the pump on the side of the motor will not pump fuel from the belly tank at all. I've tried with tank selector switch in all positions and I've tried leaving the slave cable plugged in as a power source with no luck. Anyone else had issues with this that were solvable other than by replacing that pump? Or are these pumps just prone to failure? I know it used to work because it filled the filter bowl the first time I fueled it up.
