Mep016d voltage settings
dstang97
30
Clover, SC
How do I know how to set the generator to 240v single phase. This is nothing like my mep002a? The manuals to not go into this. Also what's the chances someone installed. 400 hertz gauge on the genset? Gen head says 60cps and runs drills etc.
Isaac-1
50
SW, Louisiana
There is a reconnection switch inside the control box that lets you select 240V only mode, this is not 120/240V though, if you need to run it in 120/240v split single phase mode there is a wiring modification you can do that involves adding a single jumper wire inside the control box.
Ike
p.s. on the chance of wrong gauge I would say fairly good, mine came from GL showing less than 1 hour of run time, the reason someone hooked a 24V DC hour meter up to the AC output lines on it. Needless to say it had more hours on it, but thankfully not a lot.
dstang97
30
Clover, SC
Well what is the voltage settings on the outside for and what should I set them too? Pretty much guy wants $650 and does have voltage at the convenience outlet. Should I pull the trigger and buy it? Then buy the correct hertz gauge.
Isaac-1
50
SW, Louisiana
The switch on the outside just controls what the panel meter sees, it does not change the voltage output settings. In my limited experience with a handful of these Yanmar retrofit units, it seems little attention was paid to bells and whistles like the gauges and the control box wiring when the conversions were done. As to if you should buy it, that depends on what you want it for, personally I think the price is more than I would pay given what you have said about the condition, but that is just me.
dstang97
30
Clover, SC
So turning the dials on the outside while its running wont mater? Location is a big thing also. We have no surplus in the communist state of Connecticut.
