- 26,246
- 1,191
- 113
- NY
I recently purchased a pair of MEP017a generators at a state surplus auction. They both run and generate electricity.
One of them looked pretty oily under the oil pan(years of leakage). When I fired it up to test it, I noticed a pretty good puddle of oil forming under the oil pan. The fan seems to blow oil across the bottom of the finned oil pan, but the drip and accumulation is primarily directly under the center of the oil pan.
Has anyone else had this issue? Getting a clear view of the oil pan/underside of the engine is going to require a bit of effort to remove the air shrouding under the engine(for oil pan warming).
Looking at the TM, it looks like the oil pump is near the output shaft. It looks to have a plate that might have a gasket that may leak?
Maybe it's just the oil pan gasket? Or, a crack in something?
It only seems to leak while it's running. It has a mechanical oil pressure gauge(added by the state mechanics). I noticed it has about 80psi when cold/first started(seems kinda high compared to the other gen set).
Maybe I need to look at the oil pressure regulator?
Anyone else have a leaking 2AO42 engine,(and fixed it)?
