MEP018A wiring pics
cranetruck
75
Meadows of Dan, Virginia
Looking for actual "in service" hook-up pictures when in use by the military.
Image below shows my solution. Because of the location of my genset up high on the truck bed, a hole below the terminals works nicely to feed the heavy cable to them. Cover temporarily removed.
ida34
33
Dexter, MI
Bjorn,
Mine are still on the trailer and they are connected to a huge switch box. I can take a pic later and post. Also, you should have a hinged cover there to go over the connections for safety. Looks like yours got torn off.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Kip and I got a trailer(m103) with 2 gensets on it. It has one of those switch boxes on it. Is its purpose to just decide which genset is sending power out?
AN/ARC186
15
Graham,Washington
Looks good, I would suggest installing grommets in the holes or wrapping the cable with a wear sleeve to prevent wear through of the cable jacket and conductor insulation.
cranetruck
75
Thanks Chuck, that's what I was looking for.
Right, the whitish sleeve is a hard plastic protective cover.
