MEP16-D Wont Start
ub3rn00ber
texas dfw
I'm having trouble with my MEP16-D. I haven't run in in 2 years. I drained, cleaned, and replaced the fuel filter in the aux tank, it was gross. Replaced Fuel Lines. Aux Fuel lever set to On. Main fuel tank has never worked. It pulls fine like it has compression, but it won't start. Its set to start and the voltage is off.
What should I look at now? It is cold outside if that make any difference. I tried pull starting it about 20 times. 60 hours on unit, oil full.
Guyfang
23,945
Burgkunstadt, Germany
OK, this is the Diesel up grade set. This probably a fuel problem.
You have the AUX position for the fuel selector. And have fuel hooked to the 3 way valve. When you loosen the line to the injector and pull it over, is there any fuel coming out?
