MEP16B injector pump
nortonl
palm bay fl
I cannot get this thing off to save my life....it comes off the block about a half inch and then it is just stuck and I dont want to pull too hard and damage it. I have 2 units and both are doing the same...no fuel through the inj pump any ideas would be greatly appriciated.
nortonl
palm bay fl
Perhaps you need to look in the -34 TM. Start about at page 6-3, paragraph 6-3. Read about the removal process.
thats the first thing I did....this thing is stuck good! maybe i did not have it in the middle of it movement , it did not try to pop out as the screws came loose so i assume the cam was at the low point. Im stumped
nortonl
palm bay fl
tried moving the engine to no avail.
Guyfang
23,867
Burgkunstadt, Germany
And you followed these steps below? Centered the external arm of the governor linkage? Because that's whats holding it in.
PDF reader page 117
Remove tie wrap (6) and injection line (4).
Remove supply line (7).
Remove clamps (8) and return line (9).
Remove clamp (10) and hose (11).
MARINE CORPS TM 05926B/06509B-34
ARMY TM 5-6115-615-34
NAVY NAVFAC P-8-646-34
AIR FORCE TO 35C2-3-386-32
If pump is pushed upwards as screws (12) are removed, rotate
crankshaft approximately 90° to rotate camshaft to low
point of cam lobe.
Remove three screws (12) and washers (13).
Position external arm of governor linkage (1, Figure 6-3) to midpoint of
travel and remove injection pump (14, Figure 6-2) and shims (15).
Do not remove actuator or fork unless damaged, refer to TM 05926B/06509B-
12/TM 5-6115-615-12/NAVFAC P-8-646-12/TO 35C2-3-386-31 manual, paragraph 4-
44
nortonl
palm bay fl
PDF reader page 117
point of cam lobe.
44
Yes I did
Guyfang
23,867
The few times I had to do this procedure, it worked just like the book outlines. Wasn't easy, but it did work. When I get home, I will review the procedure again. Maybe something will click in my head.
nortonl
palm bay fl
thanks guy! this thing has been sitting for a long time so i assume its just locked up.I have 2 of them i bought on a trailer and the other one is acting the exact same way, but im scared to dissasemble both at the same time.
Guyfang
23,867
Your injection pump rack is in the wrong place. That's the only thing holding it in. Can not be anything else. I remember that we had to get it JUST RIGHT before it came out. Putting it back in is a pain also.
Just whats wrong with these sets? The probability of both having the same problem is slim. Tell us what it will and will not do.
Penzienco
Riley,Michigan
Hello new to forum. I am having same issue as this with a mep701a does anyone know how to solve this problem of stuck pump rack? Is it the plunger arm in wrong position to pull up out of block? How do I move it without tearing down engine? Thx Jp
Penzienco
Riley,Michigan
Solved with vice grips on input shaft and light tapping on pump to line up properly to remove. Hopefully didn’t mess up shaft but definitely have a partially seized pump thx
Penzienco
Riley,Michigan
On the pump there is a round pin that slides front to back to turn fuel on and off to engine ,the input shaft operated by the shutoff solenoid has a v-shaped cradle that moves the pin back and forth. The pin is likely seized. I pulled the top of injection pump apart,be careful of spring and small parts you can remove with needle nose. There is a brass sleeve down ther with a hole and grove. Spray lubricant down there and pull pump up as far as you can and try to spray lubricant down side of pump through notch in block. Remove shutoff linkage from shaft and I used vice grips on shaft after putting nut back on threads as to not damage them,maybe thereÂ’s a better way to turn shaft without damaging shaft because I did a little but think itÂ’s going to be ok. While tapping on top of pump with small hammer and putting pressure on vice grip ie shaft was able to eventually move front to back. The shaft has to be in centered position of travel in order for pump to pull straight out. On mine the flat spot on shaft was straight up, it only moves 90 degrees max back and forth. Hope this helps. Jp
Penzienco
Riley,Michigan
Also forgot to mention that if you already had linkage removed from ip shaft you could have positioned v-cradle improperly on pump pin you’ll have to pull pump up and rotate both directions while spinning ip shaft to reposition pin on cradle,you know it’s right when ip shaft will not turn without rotating pump when fully back down on block.
