MEP802 temp sensor?
bander02
Huntsville, Alabama
My MEP802 will start for just a second and then shut off. I think the wires to the coolant temp sensor are no longer connected and that may be causing the problem. The red overheat light flashes right as it is shutting off. Does anyone know which wires numbers go to the sensor in the picture that has no wires connected? It has places for 2 wires to connect. Wires are getting a little brittle and the mice are not helping. Trying to get it back on line so I can run window unit air conditioner. It is more than a little bit warm in the cabin/barn in late July. Any help/ideas would be greatly appreciated.
Light in the Dark
5,904
MA
The TMs (and respective wiring diagrams) will set you free. The coolant overtemp switch is HT (see chart):
Further in the TM diagram:
The wires involved are 115J (which comes from TB4, 14th position) and 141A (P7, 11th position). TB4 and P7 are also called out in the TMs if you need further chasing.
Light in the Dark
5,904
MA
bander02
Huntsville, Alabama
I had the Fold Out FO-2 printed out but on legal paper so my old eyes or old brain did not find the HT. I see it now right there on the bottom of page 4. Thanks for the replies. Hopefully I'll have her back up and running the AC in short order. Will reply again and let you know the status. Have a good one.
Light in the Dark
5,904
MA
In an emergency, you can completely bypass the safety system. I don't recommend doing this unless you have to, but if need be:
Turn the machine to Prime + Run, and hold in the fault light button so all stay lit. Keep holding, and crank the machine over until it runs (while still holding that button in).
With the machine running normally, and while still holding the fault button, flip up the battle short, and you can stop pressing the fault light. It should run, but be aware that your normal safety stops have been disabled.
