MEP802A 12V Generator
loca5790
Asheville
Hey All,
I have a generator that had a fire and am looking to convert it to a 12v system. What all is needed? PN's and who has done it?
I'm missing alternator (some wiring's burned up), batteries, and alternator bracket. I can make the bracket no big deal
Light in the Dark
5,713
MA
The flywheel on the generator has teeth for a 24V starter only (the 12V Lister Petter/Onan starter will engage differently). Past that, you would need to convert everything in the DC system over. Not feasible or cost effective.
If the alternator is toast, you can leave it in place but unhooked (even if you need to take the regulator off or otherwise remove the defective innards, just to keep it in place as a belt tensioner) and start the unit with 24V (then just rig up a zip tie or similar to hold the fuel shutdown solenoid open (one of the drawing items while running, that will drain a battery).
Digger556
561
Denver CO
That's a big undertaking because the entire control system is 24V. It would be a total gut job and redesign of the controls.
loca5790
Asheville
I don't have an alternator. The power draw of the unit is next to nothing. The alternator appears to be 63amp. I can easily build a buck boost/transformer circuit for a step up to run the rest of the system at 24V. I'd be surprised if the 24v starter is unable to start the system at 15ish volt.
Ray70
5,620
West greenwich/RI
I think you'll be the first to attempt a 12V conversion. Don't know of anyone ever going that route.
Seems like a lot of effort for an unknown result and the risk or damaging more original components.
Why not just repair it back to original?
Doesn't sound like that big of a deal.
If you need an alternator bracket I probably have one.
I may also have wiring, depending on what is burnt.
2Pbfeet
655
Mt. Hamilton, CA
Actually, I would be quite surprised if the 24V alternator turns the engine over at 13V. That hasn't been my experience with other engines.
As @Light in the Dark pointed out above, the fuel solenoid is a not insignificant power draw.
If you want to put in a 12V alternator, and boost the output with a 12 to 24V boost circuit, that's doable in my book, but for the effort and reliability decrease, I wouldn't do a 12V + boost conversion. To me, the point of these units is that they are built for reliability. But that's me.
All the best,
2Pbfeet
Scoobyshep
1,191
Florida
Transformers in DC are more commonly known as electromagnets. So it's not as simple. Not to mention (because it's been mentioned above) all the controls would have to be redone.
loca5790
Asheville
I'm missing alternator and alternator bracket. I'm going to redo the fuel lines in an (or attempt to) I assume they are JIC 37* flare fittings. What's everyone doing for the feed line with the banjo bolt to the injectors? Making their own AN lines?
Ray70
5,620
West greenwich/RI
Fuel lines at the pump and strainer are -4AN ( JIC-37*) If you need the hard line coming off the filter with the banjo fitting, I have that as well. if it's just your rubber lines going to the metering pumps that are leaking just cut the sleeves off and replace the hose with 1/4" rubber fuel line and clamps.
The alternators are available on occasion but getting pricey. I've gotten them on ebay before, but be sure to get one with a pulley as the pulley can be harder to find than the alternator.
loca5790
Asheville
I am missing the back lid of the air cleaner as well. I got it to crank over but it won't fire.... fuel pump is working so. Will be digging into it more. Just trying to get it all the parts together as I go through it.
  • Like
Reactions: 98G
