genmech
- 0
- 0
- Sacramento,ca
I have this issue with the AC voltmeter not showing voltage. I looked up AC VOLTMETER (VOLTS AC) DOES NOT INDICATE VOLTAGE in the TM, followed the steps, still having the issue.
Here is the kicker with changing out the AC regulator. The meter shows 220 when holding the master switch in the start position. Once I let go, it goes back to 0.
The gen outputs power, showing 24V.
Any ideas?
- Replaced the gauge, no change.
- Tested AM/VM switch, no breaks
- Tested potentiometer, showing ohms as I move it. Can't remember if it was in the 4500 to 5500 ohms range
- Replaced the AC regulator.
- Tested voltage reconnection switch, no breaks.
Any ideas?
