I have a Mep803 that will not get over 140. I am preparing to replace the thermostat this weekend. What is a safe long life coolant for these units? Do they have brass/soldered radiators?
if anyone has done research on coolant, it will make your head spin as much as researching oils.
I want to make sure to use a coolant that will protect the brass/solder (of this set has that) right away as opposed to a Dexcool or OAT type coolant that takes many hours to start protecting metals.
thank you
thank you
