MEP803a Catastrophic Failure
Russ Knight
1,053
Perry, FL
While running one of my MEP803a's during Irma, it appears unit 2 suffered a catastrophic engine failure. Don't know why, engine had adequate oil and coolant. Any ideas?
dmetalmiki
2,027
London England
Sods law!..My new all singing and dancing inverter generator quit after only 4 runs!..bought and fit new parts..we are up and running again.
1,172
What damage did it sustain?
Russ Knight
1,053
Perry, FL
Don't know. Will not crank. Apparently it has internal damage. No connecting rods through block though. Any idea what brand of engine it is? I'm going to start tearing it down later this week.
1,172
No, I am not very familiar with those units.
Light in the Dark
5,508
MA
Why do you say internal damage? Did you pull the dipstick tube and find metal? Are you just assuming? Are there any lights to indicate any conditions?
Russ Knight
1,053
Perry, FL
The engine will not turn over now. Went down on a low oil pressure fault. Oil is coming from somewhere around the front of the engine. Bummed out.
Light in the Dark
5,508
MA
Its an ONAN DN4M (technically its a Lister-Petter DN4M... but its being sourced and supported for this application by Onan). What you want is TM-9-2815-253-24 and -24P. See attached.
Light in the Dark
5,508
MA
How much oil.. a little, or a lot? Don't stick your head in the oven just yet. It might be a catastrophic breakdown... it might be something less. Just trying to be positive in this crappy time for you :)
Russ Knight
1,053
Perry, FL
A noticeable amount of oil. I'll start troubleshooting over the next few days and let you know what I find.
Thanks for the encouragement!
Light in the Dark
5,508
MA
Glad you have at least two units then! Take a few days to dry out, finish up any hurricane booze you stored up, and go through your WORKING machine to make sure its in optimal condition... then move back to the problem child. Whats that phrase... two is one, and one is none? Use the post hurricane time to really get to know the working unit. Way easier to know how its supposed to work and run, before really digging into the busted one.
glcaines
2,479
Hiawassee, Georgia
Sorry to hear about your generator problem. Good that you had two. I'm currently running on my MEP003A, but I only have one genset now.
Guyfang
23,030
Burgkunstadt, Germany
Russ,
Dont jump to conclusions. If you have just an oil leak of some type, the LOP, (low oil pressure) switch did its job. Stopped the set before it damaged the engine. Take a good deep breath, then investigate. Engine failure is rare for this gen set.
A quick way to check if the engine is locked up is to open the left side engine door. Squat down and turn your head 45 degrees to the right. You should be looking at the rear bulkhead. There should be a switch there. S10, the so called "Dead Crank Switch." It has three positions. Off, normal and crank. It has many uses. Place the switch in the crank position. The engine should turn over, but NOT start. If she turns over, it's a good sign. Keep your fingers crossed
eatont9999
DFW, Texas
My limited knowledge of these units tells me that the run circuit is open due to the low oil pressure cutout. The circuit will have to be reset after the oil leak is repaired. As to will it crank over right now, Guyfang hit the nail on the head - try the dead crank switch. If that fails, check your battery charge. Perhaps the alternator went out and it ran as long as it could until the batteries could not hold the stop solenoid open any longer. The oil leak is the most pressing issue to resolve first, though. Gotta have oil staying in it. If it's just an end seal, no big problem, those can usually be replaced without tearing the engine down.
