MEP803A ground mounted belly tank
blk65brd
Washington
Hi, new to the forum and will have a Mep803a delivered soon, I am totally off grid, have been for 15 years, I presently have a Generac 30KW John Deere diesel powered generator with a 114 Gallon belly tank , this generator will be replaced by the Mep803a. I would like to add a similar belly tank to the new to me generator. I have tried a search and come up with belly tanks on trailers and did see 1 post where someone had built their own, for the life of me I can't find that post again, any help in this matter would be greatly appreciated. I presently use solar, some limited hydro for off grid power, generator is mostly used in winter with a lot of rain and little sun here in the PNWet. Thanks for all the support on this forum, it is greatly appreciated.
Richard
blk65brd
Washington
Here is one source: https://tex-tanks.com/tanks/aboveground/belly-tank/ Can you not reuse the 114g tank for this?
The significantly cheaper method would be to just run 55g drums beside the machine, or tether it to a home heating oil tank. All scenarios (including belly tank) would require plumbing through the aux fuel inlet).
Thanks for the link, I actually have both a heating oil tank and a 55 gallon aluminum tank, what the belly tank could offer is containment of fuel, and any other leaks that may occur with the other two options. The existing Generac I have with john Deere engine has had oil leaks, coolant leaks and diesel leaks the belly tank contained them all. Although I am off grid, I have been inspected by building depts, electrical inspections and dept of ecology inspections so I do need to be careful of my choices in equipment here, this state I live in will likely outlaw anything in the near future, that emits anything carbon related.
In answer to your question, reusing the 114g tank is an excellent option, the rest of the generator is functional and could be set on rails with a smaller tank and sold.
spotrep
104
33
Texas
to be clear, you're looking for an auxiliary fuel tank to mount beneath the MEP that also has a drip tray?
Light in the Dark
5,834
MA
Well if containment and legal install is what you want, Roth tanks are an all in one option with excellent quality and are fully compliant (plus the 2" NPT tops easily allow for an MEP aux fuel adapter to be used). Standard sizes are 100g, 275g, and 400g.
blk65brd
Washington
This is a link to the generator I have this one has a 132 gal tank, mine is a 114 gallon tank, I retired from the wireless industry and the one I have Came from a cell site for backup power. From the pictures you can see the containment tray below the generator, it is about 6” deep. The original j motor on my gen was actually running with 3 of the 4 injectors broken and still making power. John Deere wanted 16K to fix it, it was replaced with a crate motor from eBay that was 4K.
-https://www.ebay.com/p/841194456?norover=1&mkevt=1&mkrid=711-153677-346401-4&mkcid=2&mkscid=102&keyword=&crlp=660656376411_&MT_ID=&geo_id=&rlsatarget=dsa-1656043178632&adpos=&device=c&mktype=&loc=9059795&poi=&abcId=&cmpgn=15152848262&sitelnk=&adgroupid=130039502099&network=g&matchtype=&gclid=Cj0KCQiAhc-sBhCEARIsAOVwHuQQAxlNR2J5jIMqorxQCOz7kPIBWqQ-4T3Tp5t-lXjO4QYObAF1POoaAnBDEALw_wcB
