hooligan327
- 7
- 3
- AK
First, I wanted to say thanks to all those who selflessly contribute their knowledge here. I'm pretty new to owning/operating one of these machines. I've had the genset for a couple years at this point but I just recently started using it to charge our off grid battery bank. It's been working pretty well. I have been charging our batteries at 10k watts which from what I've gathered is an appropriate amount of power to pull from this machine to avoid wet stacking issues. Recently it's been running rough when there's no load applied. This is especially true during cool down, but also happens sometimes at start up. The genset is outside and it's been cold. The genset is equipped with a hydronic coolant heater. When it's cold I run the heater for a couple of hours before I start the generator, usually the coolant is around 150 degrees when I start it. I keep the batteries plugged into the onboard battery tender when it's cold as well. I'll attach a link to a video of it running without a load. I would be interested in hearing thoughts on what might be going on here. Thank you in advance. https://www.youtube.com/shorts/BK1sCRliTNs
