mep803a working great but no reading on the load guage
joshua1001
Simpsonville SC
Anybody have this issue, didnt see anything on the TM. Did I overlook it? I ran the house the other day on this unit but since I didnt have an ampmeter yet I didnt proceed. Also should I see the frequency drop just a little when something big like the HVAC kicks on? Thanks for patience with a newby in advance.
Korgoth1
radford, va
Excercise the selector switch a couple times, most of the time they are crusty causing issues. Some have had faulty current transformers(test ct output, specs are in the manual), or it could be the guage itself.
jamawieb
522
Ripley/TN
I would try to rotate the reconnection switch a few dozen times to see if start getting readings. The load gauge receives it signal from a transformer and then goes to the reconnection switch, then to the gauge. I've had a few units that would read low on the load gauge and after rotating the reconnection switch, it got better. The reconnection switch, is the switch behind the gauges on the back wall, that allows you to switch phases.
DieselAddict
1,902
Efland, NC
AND Don't switch it with the generator running.
Guyfang
23,029
Burgkunstadt, Germany
Thank you Diesel Addict!!!!!!!!!!! That's the biggest killer of switches there is.
Depends on how big the load is, and how big the gen set is. But yeah, the freq meter should move a bit. Nothing earth shattering, but a bit. You may have to adjust it back up if it drops down too far.
Guyfang
23,029
When the load is large enough, the frequency, (engine speed) can drop a tad. If so, yes, adjust it back up to 60 hertz. Normally, it will only be a few hertz. A large drop in the hertz, would lead me to believe that the engine needs to be exercised at ever increasing loads to correct what everyone calls "wet stacking".
