metal vacuum pipe replacement
Chaos333
Colorado
I had a problem with my M1009 not shifting and after replacing all the hoses I did find out that it was the metal vacuum pipe. The TM listed the part number as #15599235 and it seems GM no longer makes this and NAPA does not seem to have it. I also called O'reilly's and they cannot find it. Anyone know where to get one? Right now I am using a rubber vacuum hose in it's place. I did read a thread here a while ago about someone suggesting a brake line but I cannot find that thread for the life of me. Any suggestions would be helpful.
Warthog
224
OKC, OK
Anyone parting a CUCV might have a used one. Hawkman or HillbillyWizard may have one.
The tubing is just regular steel brake line. I can't find the size right now, but most parts houses have sticks of brake line. Take a piece with you and find the right size.
The green coated brake line from NAPA bend easier than the regular stuff.
Skinny
487
Portsmouth, NH
It's just vacuum, take it to auto parts or hardware store. Use anything like copper, steel, etc. as long as the rubber line goes on tight and you don't link it.
Skinny
487
Portsmouth, NH
Most brake line is going to be copper nickel alloy, galvanized/aluminized, or epoxy coated...should be good for another 30 years.
