MFR and Year unknown
px958000
Staunton, VA
I purchased and received the following truck:
MFR UNKN, MDL: M818, ID# C124-12512, TRACTOR TRUCK, 5 TON CAPACITY, 0005. 7 HOURS, 00106. 7 MILES, WITH BATTERY AND SPARE TIRE, NO TOP, BUYER LOAD.
Approximate Dim. or Lot Cube: 265" x 98" x 112" (L x W x H)
FSC: NSN Number: Units: Description:
1. 2320 2320000508984 1 EA TRUCK TRACTOR
Now how do I determine the year of the truck so I can get tags and title.
I drove home on I64, (over 300 miles) runs great.
Thanks,
Ken
ida34
32
Dexter, MI
Start by finding the vin. Does it have a data plate on the dash? If it does check the serial number it is your vin. There have been articles about decoding the vin for a year. The manufacturer should be on the plate also unless it was a depot rebuild. I am not sure of the location of the vin on the frame of the M818 but the deuce has the vin on the drivers side front frame rail near the steering box facing to the outside. Sometimes paint has filled in the numbers so you would need to remove the paint gently till the vin was visible.
px958000
Staunton, VA
Thanks for the Welcome.
It does have a data plate but the date and the manufacturer are blank so I guess that means it is a depot rebuild. There is a label on the drivers side seat that reads xx-xx-06. I used the ID# C124-12512 for the vin # and made up the year for insurance, not sure I can do the same thing for DMV.
CARNAC
The Envelope Please.
619
Corpus Christi, TX
Here ya go
Organization: 735TH SUPPORT BATTALION COMPANY A SUPPLY AND SERVICES
Nomenclature:TRUCK TRACTOR 5-TON Model:M818 NSN:2320000508984
Serial Number:C12412512 Registration Number:5E61670 Year of Mfg:1970
Usage Miles: 17296
Hope that helps.
DDoyle
80
West Tennessee
Your truck is a 1970 Kaiser Jeep, the original army registration number was 5E61670. The VIN number is C124-12512. Welcome to the forum - lots of info like this to be had here for free, consider making a financial contribution to the site so this type info can continue to flow freely.
Regards,
David Doyle
