bdelaporte
- 0
- 0
- Orlando, FL
I am wanting to run a set of 395/85R20 tires on my truck. I am having to get a set of custom steel wheels made as it came with 18x8 wheels and 12.00R18 tires and a weird 8 lug x 270mm bolt pattern. I have a couple questions that I am hoping to get some assitance on. Pretty much new to this size stuff, so bear with me. Thanks
First the truck specs/uses:
weight 9920 lbs
2.5 ton axles
I live in Florida, trail rides with mud and sand are the main uses
It is not a daily driver but will spend time on the road (under 60 mph with these tires and gear ratio) in order to get to the trail or mud bog.
The truck has CTIS (Central tire Infaltion System) on it and I plan to be able to air down when on the trail.
The Michelin military tire website states that these tires are to be mounted on 20x10 wheels.
Q1: Has anyone ran them on any other size such as 20x11? Is it possible, advantages/disadvantages?
The bead and sidewall on these tires seem very stiff. My truck is pretty heavy (9920 lbs) but these tires are designed for 9200 lbs or so at max capacity. I have read about a few guys complaining that they have popped these tires off the wheel while under torque or lateral movement while aired down.
Q2: Do I need beadlock wheels to be able to air down to low pressure on these tires? If so, do I need double beadlocks or will a single outside BL work? Is anyone running this type (46" tall by 15.5" wide military) of tire on a standard lip wheel without the beadlocks or even the "cold roll" edge that Stazworks talks about?
The bead on these tires are pretty big (tall and thick) compared to what I am used to (Jeep CJ type stuff).
Q3: Do the standard steel wheels you buy from Diamond Racing, Stockton, Longs Wheels work well or do I need to use something with a taller "lip" to cover the entire bead?
Q4: Is there an advantage to using a recentered HEMTT wheel versus a custom steel wheel? I have seen some nice Hutchinson Aluminum HEMTT wheels for sale and I hear (Pirate 4x4 threads) that they are easy to recenter. (Cost for the steel beadlocks are about $475 each)
Any assistance would be appreciated.
weight 9920 lbs
2.5 ton axles
