Michigan Vic-1 Owners
Armada
Buick City, MI
Are there any Southern Michigan members out there with a working vic-1 intercom that I could meet up with?
I cannot get my system to function and would like to test my components on a working system to try to find the problem. These are all new components and the settings are correct but it will still not work. It is nothing but an electronic boat anchor.
Let me know. Thanks!!
Paul
ptg530C
almont, mi.
Hey-
I am in almont by boardman and vd. and have a similar problem with mine. Did you see the article on them in MV mag a couple of years ago? Are you sure your headsets are good? Murphy's surplus has new headsets with mics for $49. Whats your set doing and what do you want to test? Give eme a call at 586.354.8766
Pete
Boatcarpenter
17
Marlborough, NH
Paul, post up what is or is not happening. I don't know a lot, but mine works so maybe I can help. Do you know about the local and remote setting in the MT-1029 mount. Radio only one way, with VIC-1 the other I believe. Simple changeover. PM for link if you want instructions. Also, I would be more than willing to get my trusty digital VOM out and take some readings for you if you want.
Good Luck,
BC
jatonka
87
Ephratah, New York
I am running a VIC-1 in my Guntruck, Aces & Eights. By the Grace Of God, the first time I tried it most of it worked, just one mic was bad. I am in Upstate NY, Feel free to PM me, the truck is in the garage and I can answer questions easily. John T
1,807
2 things. If you have C-10456 crew boxes they need the center plug cap in place to work and I've had more cable issues than amp or box issues.
cranetruck
75
Meadows of Dan, Virginia
Sorry I couldn't help you more Paul.
The VIC-1 system is not reverse polarity protected and the TM says to use the MX-7777 with it. A careless installer can blow the amplifier in a hurry.
OPCOM
27
Dallas, Texas
You can connect a LS-454 speaker (as used with RT524/246) to either jack on the crew box and should hear it. If the amp is working and crew box and headset are switched to intercom, you should hear a small amount of background hiss in the headset or speaker. Note the headset audio power level is low, so don't expect blaring sound from the speaker. The impedance for speaker and mike is 150 ohms if that will help. The VIC-1 is a 'good' model because it can be serviced by a tech, so by no means should it be discarded if it is dead. The VICV-4 is potted.. when it dies, it's a pretty box with a light.
Armada
Buick City, MI
Thanks for the offers, guys. I have the mx-7777 supressor for it and the problem is the same wether it's hooked up or bypassed. The problem is I can't transmit voice, but I can hear anything else in the headset, rt524, electronic switching, static, etc. All components are NIB new. I spent a long time on the phone with ZiggyO going through everything. Right now it's all packed up and on it's way to the east coast for diagnosing. It is heavily insured so if I'm lucky it will turn up missing. In trying to keep my MV more authentic by using this system, I can say I'm not impressed with it. Maybe I'm just that one in 1000 guy whose won't function properly. I'll post what the problem is if it's diagnosed, if not I'll give directions to a new coral reef.
1,807
Your not 1 in a thousand Paul. I had VIC-1 systems in 2 trucks and stripped them out and sold them. They were very uncomfortable here in warm floida and while they did cut noise, they weren't that great with wind. Guess armor stuff doesn't have a wind issue.
OPCOM
27
Dallas, Texas
MV intercoms are not for everyone.. the mikes have to be right agaist the lips, making it hard to smoke.. the things are hot and sweaty. they cost a bunch of money, but having one that is working well is a joy. Note that on the RT unit, there is a separate audio amp in the radio that is for feeding the intercom. Indeed, one for the speaker jacks on the front of the radio, and one for the intercom. It's possible for the radio to have this failed and the intercom will not then play the radio's reception.
Boatcarpenter
17
Marlborough, NH
Sorry to hear about that situation Paul. Maybe I was lucky, but once I had collected all my pieces and gotten them installed, hit the right switches and it worked perfectly. Have only taken one ride with a passenger and it was quiet and very easy to communicate. I remember Bjorn saying once I think that the bailout connectors can be fussy, which they are, but mine work ok.
Good luck with the testing,
BC
