Mil-H-6083
FormerNewMVGuy
10
stockton NJ
I was just reading the PS article about servicing the air pack. They said to add one ounce of oht mil-h-6083. Now , is this some sort of hydruilic oil or brake fluid? Is there some sort of cross reference for this?
Just trying to make sure everything is in tip-top condition 8)
1,191
Hydraulic Fluid, Petroleum Base for Preservation and Operation (OHT) MIL-H-6083
9150-00-935-9807
9150-00-935-9808
9150-00-935-9809
9150-00-935-9810
1-qt can
1-gal can
5-gal pail
55-gal drum
NOTE: OHT should be used wherever previous documents have specified OHC.
emmado22
163
Mid Hudson Valley NY
OHT is a petroleum based hydraulic fluid. Also called "cherry jucie" by the guys that use it, opposed to FRH(Fire Resistant Hydraulic Fliud) which is called "apple juice". OHT was (and still is) used in the military.
Do a search for the MIL SPEC number on google, you'll find tons of info on it. What exactly are you looking for?
sprucemt
15
Warrensburg NY
RE: Military Specifications Lookup
And then you also have OHA.
Hydraulic fluid, petroleum base. OHA. H-515. Mil-H-5606G. NSN 9150-00-223-4134. New old stock. One gallon can. Mfg by Velsicol Chemical Co and others.
I also have this in quarts.
One has rust preventitive, one does not. I will let you all figuire it out. http://www.sprucemtsurplus.com/Misc2.html. Look under oil.
