Military "CB" Radio
79f250guy
Macedon NY
Does anyone know of any military radios that will broadcast on "CB" frequencies (26.965-27.405) i believe the german SEM-35 would work but any easier radios to find? looking to run a "military" looking radio in my hmmwv that can work as a CB
Augi
42
SF Bay Area
Any HF set that goes to 10m will do it. Legally is another question. You're supposed to be limited to 4 watts AM or something.
Augi
tennmogger
542
Greenback, TN
The SEM-35 (and SEM-25) are FM radios. CB is AM (or SSB). Otherwise the SEM radios are nice radios and cover 6 meter and 10 meter Amateur bands.
79f250guy
Macedon NY
Love that Stoner radio but seems like its an expensive unicorn. Did not realize the SEM-35 was FM that was just a quick google search. I thought about trying to make a gutted case with a cb internals. I was just reading on Radio nerds about integrating the AM-1780 into a civi radio with some circuitry. i wouldn't mind that. I am really looking for a trail radio that still fits the military look in the hmmwv. I actually just bought an AM-1780 and am looking for a couple crew stations and H-161 headsets and corresponding cables if anyone has a good source for that stuff I'd appreciate it. I may end up starting a new thread for that. Thank you for all the help thus far
aleigh
52
Phoenix, AZ & Seattle, WA
Not American, UK, but widely available is the Clansman (PRC-320). Notably it does AM which is lacking in many of the US units which were SSB and CW only.
Will be, strictly speaking, illegal to operate a military radio on CB because the individual radio has not been type-accepted by the FCC for that service. You can use military radios with the ham radio service because it is the ham radio operator who is "accepted", not the radio.
Wire Fox
161
Indianapolis, Indiana
You would still run into the legality issue aleigh mentions, but another radio that could work is a PRC-138. But, this radio would be a hellish amount of overkill for the job. You'd be about $7,000 deep in radio, mounting hardware, and supporting devices to use about $50 of radio functionality.
I think my best recommendation would be to get a rugged-looking CB radio and bolt it into the stack and use the 1780 as the main input-output for the audio, like you plan. It will look and function solidly, and not absolutely devastate the bank.
Charcoal01
Merenberg,Hessen,Germany
I took an PRC 25 T (TADIRAN) and it works on a few CB FM Cannels.The Frequencies start at 26 Mhz.See my Thread "PRC 25 Buzzing".Here in Germany we have up to 80Channels CB in FM and AM.I also worked years ago with a PRC 9,but it was not so good,low Modulation,scratchy too,the AFC is not very stabil.I have a SEM 25 too,but the Channel Steps are,with the 50khz,not compatible to the CB Frequencies.So,this Prick 25 and my RT-67are the Best working Army Radios to work on some CB Channels.
In Germany we mostly use FM Mode.
papakb
1,185
San Jose, Ca
Radios like the PRC-104, 132, 138, GRC-193, 213, 215, and 220 will all operate in the 11 meter band, expensively. A cheaper option would be a PRC-8 or an RT-66.
Mainsail
1,659
Puget Sound, WA
Instead of looking for an option that can result in a $10K fine, maybe you should look at taking an inexpensive and common CB radio and making it look more military. Some OD green paint and a couple fake rack handles on base-station CB would give you the "look", keep you legal, use common antennas and accessories, and be much cheaper overall.
Is the OP still around even?
Example: Take this radio (operates on 12v) and pull the knobs off. Then mask the display, mask the push-buttons, mask the mic hole, and plug the phones hole. Then cut out small bits of tape to cover the words and such, then blow some OD green over the whole thing.
papakb
1,185
San Jose, Ca
Mainsail, I couldn't agree with you more! 30 years ago I did just that with a couple of old Midland CB sets that I think I paid around $15 for but for some reason people all want a "military CB" of which there aren't any.
Rainman
Cuyahoga Falls, Ohio
In the early 70's, while on active duty, would set up an 11 meter long wire antenna and fire up a running spare AN/GRC-106 in a retrans rig. We could catch the skip and talked mostly into the NW states from Texas. First Sgt was a ham operator, and even fessed up years later at a reunion. He thought it was "great training" A 106 is awful lot of radio just for talking 11 meters.
Mainsail
1,659
Puget Sound, WA
In the 80s we used to fly up the east coast from Charleston AFB headed towards europe, and I would use the Collins 400 watt aircraft HF radios to talk to the CBers in the northeast. I think that wasn't allowed. Anyway, 400 watts with a 37,000 foot antenna spills out over the entire eastern seaboard and I would have dozens of people (who couldn't hear each other) trying to get in to me. I had a few regulars and we'd switch to a split channel (like 40½) and upper side band.
